Can I increase my Yamaha SS 125’s tyre size?
Home Forums Bikes Ask for Advice Can I increase my Yamaha SS 125’s tyre size?
JUMP TO CARS FORUM:
JUMP TO BIKES FORUM:
This topic contains 2 replies, has 3 voices, and was last updated by  fb-PrateekNaidu 1 month ago.
Creator
Topic
#271794
fb-DineshSingh
Newbie Motoroid
Newbie Motoroid
Topics : Level 0/5Replies : Level 0/5Likes : Level 0/5
Newbie Motoroid
Total Likes : 0
I want to change my bike rear tyre. My bike name is Yamaha SS125 and tyre size is 300-18 52P so i need solution about tyre size. I want to extend tyre size but i want to keep same wheel. Is this possible? If i can then please tell me tyre size.
Viewing 2 replies - 1 through 2 (of 2 total)
User
Replies
#271889
Amit Chhangani
Amit Chhangani
Total Likes : 1
To start off, it’s not recommended to change the standard size of the tyre for your bike. You should stick to the manufacturer’s recommendation. Increasing the size would lead to a decrease in acceleration and also in fuel efficiency while also affecting the dynamic ability of the motorcycle, mostly negatively.
However, if you MUST upsize, purely to add some more visual zing to your ride, then you should not go higher up than 1 size, and you should change both front and rear tyres, maintaining the ratio.
For example, if you are upsizing a 100/90 tyre, you should move to the size 110/80. You shouldn’t go up to 110/80 or it will have really adverse affect on the way your bike performs.
Hope that helps
#272487
fb-PrateekNaidu
Newbie Motoroid
Newbie Motoroid
Total Likes : 0
Newbie Motoroid
Apart from up sizing first you need to check whether that tyre size can be installed in the same fork area or not. Increasing the fork width is not recommended.
