Battery Size for Palio NV 1.2 ELX 2006
JUMP TO CARS FORUM:
JUMP TO BIKES FORUM:
This topic contains 1 reply, has 2 voices, and was last updated by Amit Chhangani Amit Chhangani 1 month, 2 weeks ago.
Creator
Topic
#274308
G_punitkhatnani
Newbie Motoroid
Newbie Motoroid
Topics : Level 0/5Replies : Level 0/5Likes : Level 0/5
Newbie Motoroid
Total Likes : 0
Hey guys
I have a palio NV 1.2 elx 2006 petrol
But I am a bit confused regarding Battery size
Is Amaron 44/45 din good enough or should I go for 55din instead….
N also I have a problem with gear changer shift… Sometimes it gets stuck in between…. And with that Steering wheel get jammed or locked…
It’s gets free only after I pump clutch 4 5 times…. Have changed clutch plates also…but that haven’t work out
Viewing 1 replies (of 1 total)
User
Replies
#274513
Amit Chhangani
Amit Chhangani
Total Likes : 0
Hi Punit. The Amaron DIN 44 should be sifficient for your car, unless you are using something that uses heavy electricity like a big woofer. If not, you can safely go ahead with DIN 44.
Hope that helps.
* With Inputs from Good Luck Garage Mulund West
